06-03-2012, 08:22 PM
#1
Weird pipes beside hot water heater
There are two 3 inch pipes that are in my laundry room, beside my gas hot water heater. They are side by side and one stops a couple of feet from the ceiling and the other goes closer to the floor. Both are open on the end. I believe I've seen these open up into the attic. Any explanation for why there are there? There are somewhat unsightly and if I could get rid of them, I would prefer to.
06-03-2012, 08:30 PM
#2
Persona Non Grata
Kinda hard to tell, but I think it looks like galvanized pipe to me. If so, then they should be fine to remove as they were used to provide fresh air, and exhaust the CO, from the previous gas water heater.
06-03-2012, 08:33 PM
#3
Plumbing Contractor
My guess....the one that drops closer to the floor is a fresh air intake. The other...perhaps an old flue for a previous water heater. Cant tell, but is that a gas water heater? If it is, is the exhaust piping pvc? If so, its a power vent water heater. There may have been a standard gas water heater in there at one time and someone just disconnected the flue and never got rid of it.
06-03-2012, 09:35 PM
#4
it is a gas water heater. Both pipes are vent pipes...just like what is over the current water heater. They are both so flush with the wall that I'm not sure if the short one could have ever been used as an exhaust pipe on a water heater...the placement doesn't seem possible. What I called a "laundry room" is actually more of a laundry closet in my hallway. Because it's such a small area and when the doors are closed, there's not much circulation, the fresh air intake idea seems pretty reasonable. I guess that also means that it's not the kind of thing I should remove. Here's another pic from a different view.
06-03-2012, 10:19 PM
#5
Average Joe/ex-Navy IC3
What does it look like up in the attic, where they exit the structure & on top of the roof?
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
07-28-2012, 11:38 PM
#6
It's taken me awhile to get into the attic but I got up there tonight and couldn't find the other end of the pipes. I did some digging around and found them just a few inches through the ceiling, buried in some heavy insulation (I pulled the insulation back for the photo). If their purpose was for fresh air to the gas water heater, I don't think it was doing it's job buried in the insulation. Does this mean that I can get rid of it?
07-28-2012, 11:47 PM
#7
If they starrt nowhere and go nowhere, they can go.
07-29-2012, 01:09 AM
#8
call me E
How does your existing heater get combustion air?
07-29-2012, 05:56 PM
#9
thats high and low combustion air intake. it is code to have that but honestly if you dont have the furnace and hot water heater enclosed with nowhere to get combustion air then i would rip it out. in my opinion it wastes more energy than does any good
The Following 2 Users Say Thank You to pardonme2711 For This Useful Post:
07-29-2012, 08:32 PM
#10
JOATMON
Good catch on that.....
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
08-12-2012, 07:54 PM
#11
Well I took them out...they obviously weren't doing the job that they were there for and they were a huge eyesore. If, when I sell my house, an inspector makes an issue of it, I will just reinstall them then. Thanks for all of your help.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
