Old 08-26-2007, 07:21 PM   #1
Smile
Weird layout - need advice please!!!
Hello there, new to the forum but it looks quite helpful so here goes. I am starting a remodel on a small upstairs bathroom. The current sink sits in a corner ( so it looks like a triangle) that is definatley not a 90 degree angle. I thought a possible solution would be to put in a pedestal sink but the plumbing does not come out of the wall at the corner, it's off to the side. Question #1 Can I still set the pedestal sink to the corner and get the plumbing stub out to work to fit inside of the pedestal base? Question #2: Would it be terribly difficult to move the stub out? Any other suggestions for solutions for a weird angled corner would be appreciated. Thought about a vessel sink on a floating countertop, but this option is tending to come out to be more expensive. It's a second home and I don't want to spend a wad.
On an unrelated note, anyone have any ideas for a reasonable retailer for frameless shower enclosures? Thanks a bunch...I feel stuck!
handygal is offline   Reply With Quote
Old 08-27-2007, 12:01 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
You need to know the dimensions of pedestal sink before you can know if it will work
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 08-27-2007, 09:46 AM   #3
Thanks, I have the dimensions of the sink, glacier bay petite Aragon pedestal sink: sink depth 8.5", front to back depth 17 1/8", sink width 20 1/8" X 35" height. Do I also need the inside dimension of the pedestal itself? How will I use the dimensions information to determine if it will work? Since the pipes would be off to the left of the sink I was thinking I could build a storage box that will also hide the plumbing as well as store towels since there is a storage issue as well.
Old 08-27-2007, 09:54 AM   #4
Journeyman Plumber
Pedestal has to set on the side wall to get plumbing connections to work, so maybe your best bet it to build it into a cabinet.
Need Sheetrock repair advice Giterdone Carpentry 6 02-03-2007 09:38 AM
Help for painting trim and doors: We need your advice! AaronandSteph Painting 2 01-01-2007 11:16 PM
Painting over panelling - seek advice deb14905 Painting 13 10-13-2006 08:26 PM
bathroom wall advice bigbrad123 General Discussion 9 06-07-2006 08:26 AM
