Weird Garden Hose Connector - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-11-2012, 06:14 PM   #1
weird garden hose connector
I inherited this garden hose connector from my previous owner. Other than the main water hole there is a ring of smaller holes. See picture
http://alkaspace.com/is.php?i=145087&img=IMAG0074.jpg
Needless to say that whenever I turn on the faucet water leaks from those small holes. I don't think those holes are defects because they are very regular and definitely look purposely made. I just wonder if anybody had seen this type of connector before and know what those little holes are for?
peter3484 is offline   Reply With Quote
Old 08-11-2012, 06:20 PM   #2
Rewards Points: 13,712
Looks like a back flow preventor, (Vacuum breaker) it only allows water to flow in one direction.
peter3484 (08-12-2012)
Old 08-11-2012, 07:18 PM   #3
Rewards Points: 582
yep joe is right....
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 08-11-2012, 09:14 PM   #4
Bill Kearney
Rewards Points: 1,174
It's a vacuum breaker and it shouldn't leak. If it does then remove it and replace it if desired. If you're going to use a timer on a hose then it's a good idea to use one. But if you're just connecting a hose then it's not as necessary.
wkearney99 is offline   Reply With Quote
The Following User Says Thank You to wkearney99 For This Useful Post:
Old 08-12-2012, 03:00 PM   #5
Thanks to everyone who replied. I had asked my gardener and he didn't know. This forum is great!
Yep they are definitely leaking. I guess the next challenge is to take it off so I can replace it. I'll post questions if I stumble on that one.
Pressure washer blew the garden hose tucker0104 Tools 6 05-29-2012 06:51 PM
Garden Hose faucet leaking (replacing) greentrees Landscaping & Lawn Care 9 05-13-2012 03:06 AM
running extension from outside garden hose faucet denemante Plumbing 6 05-27-2011 12:18 PM
Connect Garden Hose to Water Heater Cold Water Inlet? Geremia Plumbing 8 11-19-2010 08:50 PM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 12:27 AM
