Web Straps? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-18-2010, 10:36 AM   #1
the Musigician
DangerMouse's Avatar
Web straps?
Would these be accepted for drains and/or propane 1" steel? (From wood deliveries)
They're more than strong enough, and I roll and tape the ends to prevent unraveling. If I HAVE to go get perforated steel, I will though...
Thanks!
DM
Old 08-18-2010, 10:46 AM   #2
fabrk8r
fabrk8r's Avatar
Are you using them as hangers?
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-18-2010, 11:35 AM   #3
the Musigician
The 1" steel for the gas is stiff enough to (almost) hold itSELF up as are the drains, so it's pretty much to stabilize, rather than holding any actual weight.
DM
Old 08-18-2010, 11:36 AM   #4
the Musigician
"sag-prevention"?
lol
DM
Old 08-18-2010, 11:46 AM   #5
fabrk8r
fabrk8r's Avatar
This is in a basement along the floor joists?
When you say drain lines are you talking about waste pipe? Like 3 or 4" PVC?
I don't think it would be a problem to use it for stability (side to side). For actual support I would feel better using designed hangers, especially for 1" black iron gas pipe.
As far as the ends unraveling, instead of taping the frayed ends, try burning it slightly with a flame...as you would do to keep nylon rope from unraveling.
Old 08-18-2010, 11:56 AM   #6
the Musigician
Well whattayaknow? I found a roll of perf, so I can do both where needed. And yes, the pvc drains. The steel is galv. so it won't rust (as quickly?) so these will help if that ever happens. But my crawl is very insulated and always dry as a bone. Po) They can't complain if I use both, right? lol
DM
Old 08-18-2010, 12:36 PM   #7
Not sure where you live, but make sure galvanized steel is approved by code for gas lines. The main problem with it is flaking and clogging the gas orifices of appliances.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 08-18-2010, 01:03 PM   #8
the Musigician
Nonono, the perforated STRAPPING is galvanized, not my gas line. Plain ol' black steel 1". Po)
DM
Old 08-18-2010, 02:32 PM   #9
Thanks for the clarification. I see no problem with either type strapping as long as your local code does not have any strict requirements.
Gable dormer construction questions Joe1. Building & Construction 21 08-01-2010 11:17 PM
Straps for securing gas line to joists - question. DangerMouse HVAC 4 07-05-2010 09:20 PM
Exterior Sheathing Repair Earnie Building & Construction 19 02-14-2010 10:32 PM
Sub Panel Main Lug Load Center - Single Phase ? Roy Rowlett Electrical 21 08-20-2009 07:55 PM
Overhead Service - SER Cable robertmee Electrical 21 10-14-2007 07:25 PM
