Weak Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-10-2006, 01:40 PM   #1
Weak water pressure
I just moved into a new apartment on the 2nd floor of a 5 floor manhattan building, and had it renovated. Now the water pressure is weaker in the kitchen and awful in the shower. Is there any way to boost pressure for the whole apartment?
jd5074 is offline   Reply With Quote
Old 12-10-2006, 01:51 PM   #2
Welcome to the Chatroom. Since you are in the city, I doubt you are on well water. Your water pressure should be the same at all fixtures. You said you had the Apt. renovated. Did this include plumbing renovation? A valve (or two) may have not been opened all the way or if the water was off for any length of time, scale that was inside the pipes may have broken loose and is now clogging the pipes or aerators. Remove the showerhead and turn the water on. If the pressure is better, clean the head. Remove the aerator on the end of the sink spout and also turn the water on to see if that makes a difference. These are common things that can make water pressure seem lower. Let us know how this works out.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Water pressure? What water pressure? mnp13 Plumbing 9 05-03-2007 02:32 PM
water pressure problem rgmetro Plumbing 6 04-09-2007 03:57 PM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 09:04 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 08:05 AM
New Help With Improving Water Pressure hayhursm Plumbing 1 01-31-2006 06:55 PM
