Weak Stream Of Water From Shower Head. - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-01-2008, 12:33 AM   #1
Weak stream of water from shower head.
I have two showers in my house. One of them is a dedicated shower only and the other one is a tub with a shower head on top. The dedicated shower only has a weak stream of water coming from the head. At first I thought it was the shower head because I bought a cheapo $10 one from wal-mart.
So I bought a $40 shower head that was rated 2.5gpm. It still felt weak.
Before I replaced the cheapo $10 head with the $40 one, I also repaired the leak in the shower. I replaced the "Sayco" steam because it had a missing gasket. I did fix the leak, but I don't know if what I did had any effect on the weak flow of water. I also noticed the knob where you turn on the water is very loose compared the old Sayco steam that I had before.
Is there any quick fix that I can do to make the flow stronger? The water flow throughout the house seems fine.
SuperAkuma is offline   Reply With Quote
Old 08-01-2008, 08:25 AM   #2
There is a rubber gasket that allows the water to go through at a snails pace. Try replacing the rubber gasket with a new one that has a larger diameter hole.
JohnJak is offline   Reply With Quote
Old 08-01-2008, 06:33 PM   #3
Send a message via AIM to Marlin
Did the weak flow start when you changed the cartridge or was it always like that? I take it this is a single handle shower body? How old is it?
Marlin is offline   Reply With Quote
Old 08-01-2008, 06:49 PM   #4
The weak flow was there before I changed it. This is a two handle shower body. I don't know how old it is, but the house was built in 1976.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Water dripping in the shower??? Sellncars Plumbing 4 12-05-2009 09:07 PM
very low shower head flow rickard681 Plumbing 7 10-08-2008 07:43 AM
HELP - Lost water pressure to shower after turning off water to house jpw28 Plumbing 8 02-20-2008 09:07 PM
No flow to shower head; toilet runs constantly kathleentsy Plumbing 7 05-17-2007 10:05 AM
