-   -   Weak stream of water from shower head. (http://www.diychatroom.com/f7/weak-stream-water-shower-head-24561/)
SuperAkuma 08-01-2008 12:33 AM
I have two showers in my house. One of them is a dedicated shower only and the other one is a tub with a shower head on top. The dedicated shower only has a weak stream of water coming from the head. At first I thought it was the shower head because I bought a cheapo $10 one from wal-mart.
So I bought a $40 shower head that was rated 2.5gpm. It still felt weak.
Before I replaced the cheapo $10 head with the $40 one, I also repaired the leak in the shower. I replaced the "Sayco" steam because it had a missing gasket. I did fix the leak, but I don't know if what I did had any effect on the weak flow of water. I also noticed the knob where you turn on the water is very loose compared the old Sayco steam that I had before.
Is there any quick fix that I can do to make the flow stronger? The water flow throughout the house seems fine.
JohnJak 08-01-2008 08:25 AM
There is a rubber gasket that allows the water to go through at a snails pace. Try replacing the rubber gasket with a new one that has a larger diameter hole.
Marlin 08-01-2008 06:33 PM
Did the weak flow start when you changed the cartridge or was it always like that? I take it this is a single handle shower body? How old is it?
SuperAkuma 08-01-2008 06:49 PM
The weak flow was there before I changed it. This is a two handle shower body. I don't know how old it is, but the house was built in 1976.
