Wc Leakage, Supply Inflow - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-15-2009, 01:09 PM   #1
Wc leakage, supply inflow
Periodically (for no apparent reason), the water supply valve opens and "tops off" the quantity in the water closet. Can anyone tell me why this happens, and how (other than installing a new water level control) I can fix it? Many thanks, . . . Helper56
helper56 is offline   Reply With Quote
Old 03-15-2009, 02:16 PM   #2
Rewards Points: 1,418
Replace the ball or flapper at the bottom of the tank. Over the years it could get hard and not seal well and you really have a slow leak down to the bowl which is the reason for topping off.
Old 03-15-2009, 05:14 PM   #3
Most likely, the fill-valve is doing what it is supposed to do, keep the tank water level at the proper height. I am guessing that you have a leak through the flapper. When the water level in the tank reaches a certain point, the fill valve replenishes the water. Try adding some food coloring to the tanks water and watch the bowl for an hour. If the water in the bowl changes color, you need to clean or replace the flapper. May also need a chain length adjustment. The chain only needs to allow the flapper to "just" seal.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
How to install thermostatic reactive valve and repack supply valve Leah Frances How To Guides 1 06-10-2009 11:49 AM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 10:26 PM
Darn. A leak in my main supply from street, Galvanized. In foundation under slab? twilightcall Plumbing 2 07-31-2008 01:22 AM
Galvenized supply to PEX, How to make connection? twilightcall Plumbing 4 07-28-2008 10:28 PM
Supply Line Touching Roof MikeinBurien Electrical 14 07-13-2008 12:26 PM
