Old 05-31-2009, 10:46 AM   #1
Old School
cabinetman's Avatar
Default Wax Toilet Ring Question
I'm doing a bathroom renovation, including installing a new toilet. A little background on my plumbing endeavors... I hate plumbing.
Anyway, my question is pretty simple. Which ring, and where to place it when setting down the toilet. When we had our sewer line hook up, our plumber removed one toilet and when he re-installed it he used a regular ring and placed it on the floor flange, not the underside of the toilet. He also did not recommend using the one with a plastic funnel because they reduce the orifice size for waste flow.
Well, I'm kind of "follow the instructions guy". The instructions with the toilet says to place it on the underside of the toilet, and the included wax ring was just a plain ol' ring.
All of the toilets I've ever installed I placed the ring on the toilet first. Some of the websites I checked out says to put it on the floor, others say put it on the toilet. Which is best? And, which ring is best?
Oh, one more thing. A few websites recommend not using the plastic catch tabs for the bolt covers. They say that as they can wear from any movement and weight transfer, will create the possibility for leaks. Is there any truth to that?
cabinetman is offline   Reply With Quote
Old 05-31-2009, 10:52 AM   #2
Either way works fine. I prefer putting them on the bottom of the bowl simply because there is less chance of it slipping and blocking the pipe but I have done it both ways with out any problems. As far a s the plastic catch tabs what I do is put the catch tab on first then put a metal washer over it then the nut. This keeps the plastic catch tab from moving and squeezing down too much.
al's sewer is offline   Reply With Quote
Old 05-31-2009, 12:12 PM   #3
I have always put the seal on the flange. This way, you don't need to worry about it dropping off while setting the toilet. If the closet bolts don't come with tabs to hold them upright, I squeeze some of the seal around the bolts to hold them straight while setting the toilet. I have no problems with the wax seal that has a plastic funnel on it. Look at the discharge hole on your toilet and you will see that it is much smaller than the flange opening, even with this type seal. A properly set toilet should not move at all so I don't see the reasoning for not using the plastic catch tabs. I install them as Al said, under the nut and washer.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
More On This Topic
Removing a Toilet
Removing a Toilet by Expert Village
Now, before we pull a toilet, we've emptied the tank for the water. That was easy, but we need to empty the bowl of the water. So what we'll do is we'll pour a bucket of water; half a bucket of water in the toilet, and we'll pull it kind of fast, and the... Read More »
My name is Jeff Pence and I am with Bob Street today from Houdini Home Improvement in Lebanon, Ohio on behalf of Expert Village. In this clip, we will be installing the toilet bowl under the wax ring onto the sewer pipe. First we will carry it in... Read More »
All right, so we notice that the wax ring is a little low on this side, so when we reset the toilet we're going to keep an eye out to make sure that that has the proper amount of wax on there. We want to remove all the excess wax; make sure we don't get... Read More »
How to Install a Toilet
How to Install a Toilet by Expert Village
Today we’re installing a new toilet. You’ve already cleaned up the area and gotten it all prepped and assembled your toilet. You want to take the toilet bolts and slide them into the hole right here and put them on the side to where they... Read More »
Ok, now I'm going to take the toilet, I've got it all in one piece already because its a used toilet and we're going to set it in place. Ok, now I'm a little bit up off the floor because my toilet is just now beginning to squish that wax ring down into... Read More »
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 4 01-11-2009 01:06 PM
Toilet Wax Ring & Horn capt2 Plumbing 2 07-19-2008 11:24 PM
toilet leak after replace new wax ring druffino Plumbing 4 07-18-2008 12:31 AM
Which is better? WAX or Non-Wax toilet ring? KUIPORNG Plumbing 15 02-20-2008 04:23 AM
Macerating toilet question rjniles Plumbing 0 03-08-2007 10:12 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
