Old 01-02-2013, 04:06 PM   #1
Question
wax ring thickness
Hello.
There seems to be a lot of differing opinion on what the optimum position of the flange (relative to the finished floor) should be.
The top of my closet flange sits about 1/4" (plus or minus about 1/16") above my finished floor.
My question is whether or not a standard wax ring would work for a flange set at this height, or if I should go with a thicker ring? I'm thinking about using the thicker ring, but I'm wondering if it is possible to actually use too much (too thick) wax, creating a problem?
Thanks,
Corey
corman is offline   Reply With Quote
Old 01-02-2013, 04:19 PM   #2
wax ring thickness
No a thicker one will not cause an issue, one thing I would do is sit on the toilet to smoosh it down , snug the nuts up, use it a few days and do it again to make sure it's snug.
Old 01-02-2013, 10:41 PM   #3
wax ring thickness
Thanks for the reply. I'll go with the thicker ring.
Cheers,
Corey
Tags
flange, hieght, ring, thickness, wax thickness
There is no two gang mud ring & wall plate for a CENTERED switch? miamicuse Electrical 4 06-07-2012 06:34 PM
closet ring flange help/explaination eyeglass Plumbing 2 09-09-2009 07:35 PM
Wax Toilet Ring Question cabinetman Plumbing 2 05-31-2009 11:12 AM
Toilet Wax Ring & Horn capt2 Plumbing 2 07-19-2008 10:24 PM
Which is better? WAX or Non-Wax toilet ring? KUIPORNG Plumbing 15 02-20-2008 03:23 AM
