Old 02-23-2009, 05:09 PM   #1
Electrician
ctsmiths's Avatar
Wax ring
Im installing new tileing on my bathroom floor and I will be adding a new subfloor under the tile. Needless to say the floor will be higher than it used to be, is there a special wax ring that I need?, and if so can someone post a link to it. Thanks
ctsmiths is offline   Reply With Quote
Old 02-23-2009, 09:24 PM   #2
Wax ring
You will need a spacer ring to bring the flange up to a 1/4 inch above the finished floor or less just don't be to high or the toilet will sit funny too high!
you can also double up wax rings so you will just squeeze out the extra .
you can buy a flanged ring and insert it into a regular wax ring this will fill a void in floor differences. good luck
plumbbum0203 is offline   Reply With Quote
Old 02-24-2009, 06:43 AM   #3
plumbing contractor
PLUMBINGITALL's Avatar
Wax ring
The correct way is to use a closet flang extension's kit. It comes with long toilet bolts 2or3 risers. Just make sure to use silcone in between each flang extension
PLUMBINGITALL is offline   Reply With Quote
Old 02-24-2009, 11:50 AM   #4
Wax ring
Use a Closet Flange extender. Available at Lowes and Home Depot. They are available in different thickness (or can be stacked) to obtain the height you need. Just make sure to secure them through the original flange, to the floor. I use silicone between the extender and original flange. While doubling up on wax seals is sometimes done, you can also cause problems if the seal slides while installing the bowl. This can result in blockage of the drain.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 02-24-2009, 04:50 PM   #5
Electrician
ctsmiths's Avatar
Wax ring
Thanks for the help!!!
Old 02-24-2009, 11:40 PM   #6
GC/Master Plumber/Mech
Wax ring
NEVER DOUBLE STACK WAX RINGS. Take the time to raise the flange and if you are intimidated get a Licensed plumber. When those rings start leaking into the crawl space or on top of finished drywall you will thank me. They also have different size of wax rings.
Removing compression ring? ruzz Plumbing 30 10-01-2011 07:14 PM
Can I use ring shank nails for framing? bluefitness Building & Construction 3 12-18-2008 10:17 PM
Ring Main Question Andyjr Electrical 5 09-14-2008 10:47 PM
Toilet Wax Ring & Horn capt2 Plumbing 2 07-19-2008 10:24 PM
Which is better? WAX or Non-Wax toilet ring? KUIPORNG Plumbing 15 02-20-2008 03:23 AM
