Prev Previous Post   Next Post Next
Old 01-16-2009, 03:09 PM   #1
Default watts regulator B1156F instructions
Can someone point me to a site or a PDF with the instructions as to how to set this valve? The water PSI in my boiler is a little high I would like to make an adjustment and I'm not sure if I need to turn the handle to the left or right and whether the set nut needs to be loosened.
cyberplaid is offline   Reply With Quote
More On This Topic
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. Some of the common things you want to watch for in framing, is to make sure that all of your walls are plum, level and square. This keeps everything... Read More »
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. The budget is very important because that gives you an accurate idea of how much you're going to spend on the project and that way you can stay within that... Read More »
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. When framing the basement, we try to find the longest wall possible and square from that wall on. In this basement, this would be that wall. This is a great... Read More »
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. The insulation is a project that's very simple and and something I would actually suggest for a homeowner to try to do themselves. In this home here we... Read More »
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. The schedule that you'll use when finishing a basement is very similar to the schedule that you'll use when finishing a home. In fact, it's almost exactly... Read More »
Btu's and watts Steelhead Electrical 11 01-04-2009 08:23 PM
any instructions on how to install aluminum porch enclosure? brisk Building & Construction 2 12-14-2007 08:01 PM
DIY electrical work questions for finishing a basement. mac41099 Electrical 7 11-16-2007 09:59 PM
Watts vs. Volt-Amp Billing? Max P Electrical 19 07-24-2007 09:05 AM
Watts to Amp Rze Electrical 2 08-10-2006 02:57 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
