Watse For A Toilet! - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-05-2008, 11:50 AM   #1
watse for a toilet!
When buying a new toilet is the measurement for the waste given the measurement for the centre of the waste pipe? thanks
merry1984 is offline   Reply With Quote
Old 06-05-2008, 12:29 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Yes. Most toilets flanges/pipes are installed 12" on center from the finished wall.
Mike
Mike Swearingen is offline   Reply With Quote
Old 06-05-2008, 02:30 PM   #3
Registered User
Termite's Avatar
Mike
Although it isn't adopted in every jusrisdiction nationwide, the International Residential Code requires a minimum 15" from center of the water closet to the finished wall. Been that way since 2000.
Old 06-05-2008, 04:12 PM   #4
You're referring to minimum side distance from center of bowl to finished wall.
My state requires 18".
I beleive the opening question was in relation to rough in size, the distance from rear finish wall to center of drain.
3 sizes - 10", 12" & 14" - 12" is standard, the other two are less often seen.
Plumbermark is offline   Reply With Quote
Old 06-06-2008, 09:24 AM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
While 15 may be minimum from a side wall and/or cabinetry, if you have more, it will be a lot more comfortable. Less will be really difficult to take a poop.
Journeyman Plumber
Old 06-06-2008, 09:44 AM   #6
Registered User
Termite's Avatar
Correct. Out of curiosity, what state requires 18"?
Old 06-06-2008, 10:51 AM   #7
47_47's Avatar
Rewards Points: 62
Alan,
Not to argue with a pro, but I usually leave a poop.
47_47 is offline   Reply With Quote
Old 06-06-2008, 12:25 PM   #8
Long-Time DIYer
Don't know about side requirements, but I'm now solely into the boat and drinking beer. LOL
Old 06-06-2008, 02:15 PM   #9
Of the small handful of states that don't incorporate UPC, IPC or BOCA...I'm one of them.
Never a fun time attempting to relate to codes that cover multiple states.
Old 06-07-2008, 02:01 AM   #10
Doing it myself
Alan's Avatar
Originally Posted by 47_47 View Post
Alan,
Have it your way.
Journeyman Plumber
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 03:43 PM
why one toilet backs up and other does not Richmarti12 Plumbing 2 03-16-2008 02:22 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
Installing an attach-to-floor toilet? johnny4321 Plumbing 5 11-22-2007 01:34 AM
