Waterproof Shower Grout - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-27-2011, 08:38 PM   #1
Rewards Points: 113
waterproof shower grout
Several years ago I used 12"x12' tiles in my shower and 1/4" grout lines. I used tub & bath caulking at the floor where the wall meets the pan tile. About every 7-8 months, I must re-seal the tile and replace the caulking as water penetration releases the caulking. And there are days of waiting to allow the grout to dry out before applying the sealer.
Well, I don't want another grout sealer. I want a waterproofer!! I am at the point of removing all the grout ( about 50 L. ft. ) and replace with an epoxy grout. Is there a water proofer that will save me tons of work??
BTW, I removed all the tile and mortar around the drail to verify that the mortor pan weep holes were not stopped up.
Captflx is offline   Reply With Quote
Old 02-27-2011, 08:43 PM   #2
Experienced
Jackofall1's Avatar
Sounds to me like you have something else going on to have the caulk release every 7-8 mths, sounds like you have excessive movement of the pan it self.
Tiled, sealed with a standard sealer and never touch it again.
Mark
Old 02-28-2011, 06:36 AM   #3
Rewards Points: 113
Nothing else going on. No gout cracks, no movement. The only sealers I've found says " when tile starts to absorb moisture, it is time to reseal---6 months to a year". Since I have light colored grout, it is very evident when it starts to absorb moisture again.
What sealer did you use?
Old 03-07-2011, 12:08 AM   #4
Master of none
I'm confused!~
I find your post confusing! Is the grout coming off? Does the caulking come loose?
Is your caulk silicone or acrylic? Did you say the tile needs resealing or the grout? If the grout comes out, then it is definitely defective!
Now it occurs to me!! Did you use an unsanded grout? I you have 1/4 inch grout lines, you should definitely use sanded grout.
handy andy is offline   Reply With Quote
Old 03-07-2011, 09:14 AM   #5
Rewards Points: 1,442
Leave the bathroom door and the shower curtain open when not in use. This allows moisture that got into the normally slightly porous grout to come back out and evaporate rather than persist and accumulate in the wall.
If grout keeps releasing, chances are that in an earlier lifetime soap got in and the residue keeps the new grout from sticking.
Old 03-08-2011, 11:16 PM   #6
Rewards Points: 113
Clarification. The grout is a sanded grout. The grout is not coming loose. It is solid everywhere. The caulking between the tiled shower wall and the tiled shower floor is coming loose and there is obviously alot of moisture behind the caulking. I am using a latex caulk made for baths.
Old 03-09-2011, 07:01 AM   #7
DIY staff
Rewards Points: 7,174
Latex caulk is the problem---100% silicone is what you need---Clean--dry--caulk with silicone--should be good for many years.---Mike---
Old 03-10-2011, 11:36 PM   #8
Rewards Points: 113
Thanks Oh'mike. I'll try that next.
Old 03-10-2011, 11:46 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The gap must be cleaned out and dried totally before you install any new caulk. The caulk is releasing because the crack is not totally dry when you install the new caulk.
Put a fan in there for forty-eight hours, then re-caulk with any suitable tub and tile caulk.
Then wait another seventy-two hours before you use the facility.
XXX
Old 03-13-2011, 07:39 PM   #10
Rewards Points: 113
Opening being damp is not the problem. I have left a fan blowing on it for days. Believe me---the opening was totally dry.
Old 03-13-2011, 08:57 PM   #11
My local lumber store has a Dap (?) tub and sink silicone that is 'fast dry'. According to the label, dry in a couple of hours. I haven't used it, but it might be worth looking into.
darrell
Darrellj is offline   Reply With Quote
Old 03-13-2011, 10:21 PM   #12
msaeger's Avatar
Rewards Points: 260
I can second that. All the crap the used in my house was latex and it all cracked / pulled away. I have replaced some with 100% silicone and it has not cracked. I just need to get around to doing all of it
msaeger is offline   Reply With Quote
Hairline crack in shower floor grout. Should I care? wsutard Tiling, ceramics, marble 11 11-21-2010 08:57 PM
Shower Floor Grout Prob. MEH Tiling, ceramics, marble 1 11-05-2010 08:55 PM
Shower grout discoloration Teebadoe Kitchen & Bath Remodeling 2 11-03-2010 08:07 PM
Repairing missing grout in shower stall CLM Tiling, ceramics, marble 14 10-03-2010 11:08 PM
Grout question poolecw Flooring 11 10-29-2008 08:32 PM
