Old 10-02-2011, 07:00 PM   #1
Waterite water softner
I have a waterite water softner that when it isnt bypassed I turn the tap on great pressure and the go's to nothing, I have removered my fiberglass tank and the sand is up to the top. Here is the thing my brother had a water softner the head unit went so I have his tank and put it on my unit but is is smaller in size. Is this ok or will I run into a problem......I will post a pic of my tank with the sand to the top....What has happened to it...any help greatly appreciated.....Derek
derek70 is offline   Reply With Quote
Old 10-03-2011, 12:06 PM   #2
Water Treatment
The stuff at the top of the tank looks more like resin.
If your system has sand, then a sand filter is going to be needed or it will happen again.
Akpsdvan is offline   Reply With Quote
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 09:35 AM
No hot water past the valve at top of hot water heater-?- Daulton Plumbing 4 04-03-2011 03:47 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
