Old 11-15-2008, 02:20 AM   #1
Waterheater nightmare + too much pressure in house
being green and not realizing @ the time i made a big mistake
and now im paying for it
i was short on cash
my old WH was leaking on the outside of the seals (slowly) from the T P valve and wanted to change out before it blew on me
bought new powermiser9 40 g. from sears and figured i'd craiglists a plumber to do it cheaper than the $300 price for a sears guy to do it
install went good, until shortly after we turned water on, TP valve
starts leaking again? but from the actual faucet this time
did some research and found out about the thermal expansion tank
just recently installed that, and still leaking
found out about the pressure reducing valve,
turn it down to 40 psi and it IS STILL LEAKING OUT OF T P VALVE
i have a digital pressure gauge that i have been monoriting the expansion tank, and when the T P valve is leaking, i have noticed both
140 psi and 0 psi
please help me end this nightmare quickly
and as gentle on the pocketbook as possible
like i havent learned that lesson already
thx for reading and responding
lukin
lukin is offline   Reply With Quote
Old 11-15-2008, 03:15 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
First, get an inexpensive water pressure gauge from any hardware store or big box. It will fit on hose threads, so you can put it on the bottom heater drain valve or an outside spigot to check the actual water pressure at your house. This will verify if your pressure reducing valve is working properly. If it isn't, the PRV may need to be replaced if you have adjusted it properly and it isn't functioning correctly.
If you have a PRV, then you always need an expansion tank because the PRV creates a "closed" system.
Next, carefully open and close your heater T&P valve quickly to flush out any debris that may be holding it open causing it to "leak". That could be your only problem if the pressure is where it should be.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
200 Amp service really needed for a 830 sq ft house? overkill? alexz Electrical 7 11-16-2009 06:54 PM
EXcessive moisture in house geema HVAC 5 09-10-2008 12:18 PM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 10:04 PM
Will my house make my kids sick??? jokrupinski General Discussion 18 09-29-2006 05:05 AM
