#1 |
Water worse after draining hot water heater
We own a home with well water and for a little while we have been noticing a rotten egg odor. A few months ago we had a green sand filter installed to remove that (we already have a salt water softener, so now we have two systems).
The odor kept coming so after several service calls confirming the softener was working fine, we decided to flush the hot water heater (which is 4 years old). After the first flush, we used our inline filter to dispense bleach into the hot water heater. The water seemed to smell better. Not too long after we noticed our drippy shower head was leaving iron stains on the floor and our white dishes were stained brown/orange. I manually regenerated the green sand system and it is still bad. The water smells a little fishy/metallic now, and the water is so brown orange it stains anything it comes in contact with. What happened? |
#2 |
Average Joe/ex-Navy IC3
You killed the filter by pouring Bleach through it.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
#3 |
Super Moderator
Remove the sacrificial anode rod inside of the water heater----your bleaching exposed fresh metal---which is now reacting with the Iron and sulfur in the water---
New members: Adding your location to your profile helps in many ways.--M-- |
#4 |
The problem is most likely the anode rod in the water heater and removing it will probably stop the smell--but it will also accelerate the demise of the water heater. Replacing the anode rode with one of a different compostion usually solves the probem. There are also powered anode rods.
See here: http://www.waterheaterrescue.com/pag...r-heaters.html |
#5 |
Thank you... I had a feeling it was a reaction with the adnode rod. I'm trying to remove it but the bolt is giving us a hell of a time. We may remove it altogether even though we bought a replacement.
#6 |
Most of the time you have to use an air power impact gun to get them out.
| Tags |
hot water heater, iron, smelly water ![]() |
| Display Modes | |
| Tankless Water Heater | a7ecorsair | Plumbing | 56 | 05-04-2012 10:17 AM |
| rumbling pipes and leaking pressure relief valve | rogerwright | Plumbing | 21 | 04-14-2012 03:35 PM |
| A blocked water line causing water to loose heat? | Snav | Plumbing | 6 | 05-07-2010 03:18 PM |
| Periodic release from (I think) the T&P valve on the water heater | alexz | Plumbing | 3 | 08-15-2006 11:31 AM |
| New Water Heater, worse pressure | Repoman75 | Plumbing | 6 | 04-16-2005 12:30 AM |
