Water Won't Drain From Tank When Flushed. - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-25-2011, 05:04 PM   #1
Water won't drain from tank when flushed.
My toilet fills ok, but when you press the handle, the flapper raises, but the water won't go down. It dribbles very slowly, but does not "flush"
HELP!!!
bustertheclown is offline   Reply With Quote
Old 09-25-2011, 05:09 PM   #2
DIY staff
Rewards Points: 7,174
Have you reached into the tank and lifted up the flapper?
Most likely the flapper is old and needs replacing.
Old 09-25-2011, 06:03 PM   #3
flapper is not the problem
I can see the flapper raise, the water just will not go down.
Old 09-25-2011, 06:13 PM   #4
DIY staff
Reach in the tank and remove the flapper completely---then tell me what happens.
Old 09-25-2011, 10:38 PM   #5
problem solved.. thanks
Old 09-26-2011, 07:59 AM   #6
DIY staff
Good to hear it----what worked?
Old 09-26-2011, 09:35 AM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Toy under the flapper was my original guess.
Would love to hear the actual outcome though.
Journeyman Plumber
Old 09-26-2011, 09:43 AM   #8
DIY staff
We will never know-----
Tags
flapper , flush , tank , toilet , water
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
Sewage smell from shower drain, trap has water, vent was snaked and was clear clearasmud Plumbing 1 04-24-2011 06:28 AM
How do I drain my water heater? HVAC_NW Plumbing 10 11-10-2010 03:15 PM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 05:40 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
