Water Well Serving Two Houses - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-02-2012, 04:16 AM   #1
water well serving two houses
My brother and i share a well.we recently switched the electrical from my house to his by diconnecting the wire leads from my house and connecting the leads to his.
we are now haveing a problem ,we cannot get any water to my side withoout first turning on the water at his house and running it till the pump cuts on. we made sure his plumbing was the same as mine at the pressure tank before switching the power supply. does anyone have any ideas?? thanks
gad970 is offline   Reply With Quote
Old 08-02-2012, 10:19 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Is the ONLY thing you changed the electrical or did you mess with the plumbing as well?
A diagram of the system would help.
Journeyman Plumber
Old 08-02-2012, 10:43 AM   #3
Rewards Points: 13,300
It should have made any differance if the plumbing was not changed.
Just a guess, is the pump wired for 110 or 220? Are you sure you did not try running it on 110 when it's wired for 220?
One water well serving two houses mdkelly77 Plumbing 9 03-21-2012 04:39 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
