Old 05-15-2008, 01:16 PM   #1
master of no trades
The Barber's Avatar
water well questions.
I just bought an older home I am updating and remodling as I live in it. I have an old water well I was checking out. the motor and pump (jet type) are siezed up. No fixing. I want to replace it but I do not want to spend a fortune on it. as I am on city water I do not need it I just want it working. the well is 150 feet deep and I hit water at approxamitly 75 feet. I want to use it to water the yard and fill my pool from time to time. With what should I replace it. what do you suggest.
The Barber is offline   Reply With Quote
Old 05-17-2008, 01:56 AM   #2
Doing it myself
Alan's Avatar
Free bump : although I don't know enough about pumps to really answer your question, I do know that you definitely don't want to tie your well water into any water system in your house carrying city water without approval from the city and any other authorities that have jurisdiction over water, and IF they allow it, they will want it professionally installed with protection devices as well as permits and inspections....
However, if you're using it on a complete separate system, you will be fine.
good luck!
Journeyman Plumber
Old 05-17-2008, 03:36 PM   #3
I replaced my old pump, at last house for under a $100, take a look at the big box stores, they carry them. You could pipe it to a spigot for outside use. If you decide to use it for drinking water, get a water sample tested. I don't know the logistics, but at over 75' you might not be talking old style hand pump here, good luck to you.
DUDE! is offline   Reply With Quote
Old 05-17-2008, 04:52 PM   #4
master of no trades
The Barber's Avatar
Thank you for replying guys! I will be using it as a separate system all together.
As I said I will be using it to fill my pool and water the lawn. I will not be tapping it into my house. Where I live almost all my neighbors have a well and they all have good drinking water. I probably will have it tested just to be on the safe side. When you say big box stores I do not follow you. Do you mean a local tool house store? Sam's wear house something like that?I didn't think about my local tool house store, I will check them out. The pump i pulled out of the well was one of the old jet type pumps. thanks again guys.
Old 05-17-2008, 09:17 PM   #5
I was mistaken on your pump type, mine was not submersible, so I am wrong on the price, sorry, by big box store, I was refering to a home depot or a lowes, your local hardware store may indeed care them, at the least you could price them out there.
Water Mystery - Sump Pump Set Right? robertr4836 General Discussion 4 02-13-2008 03:32 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 10:03 AM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 01:27 AM
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 04:28 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
