Water Well In A Crawl Space - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-07-2011, 06:59 PM   #1
Water well in a crawl space
Hi all.
For my first post I want ask about a problem I'm facing in preparation for a fairly extensive addition to my house. This proposed addition will extend out over the location of my exterior well house and cover the water well. I'm confident that I can arrange the pump and tank so they will fit in the crawlspace, but a friend of mine told me that it would be necessary to maintain open access to the well so the pump line can be removed if needed. If this is true, then I may have to abandon my plan or have a new well drilled at a cost of several thousand. But I'm wondering if there is a creative solution to this problem? Can I perhaps remove the current pump system and replace it with something that has a flexible production pipe. That would be much better than having to drill a new well. Any thoughts about this solution or other work-arounds? Thanks
Okie0030 is offline   Reply With Quote
Old 03-07-2011, 07:13 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 342
Ayuh,... I can't feature a flexable hose being able to take the torque of a submersible pump...
It'll Rip up black plastic pipe, if ya don't use torque isolators...
How far down is the pump,..??
Old 03-07-2011, 08:53 PM   #3
Rewards Points: 1,418
How about removable floor panels in the new building addition over the well?
Old 03-07-2011, 08:56 PM   #4
How much headroom is there in the crawl space? If not much then I would recommend having the expansion tank and other parts of the system in the house on the main level.
Old 03-08-2011, 06:52 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
You may find your building dept. will not allow you to do this. If you well has problems in the future, how could a well drilling rig be used to deepen the well? You might not care but a future owner might get stuck.
I would change the plan or drill a new well.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 03-08-2011, 09:20 AM   #6
What if I used an above-ground pump?
I'm not sure how deep the well is. Just bought the house. I'll have to look that up.
Old 03-08-2011, 09:23 AM   #7
I thought about removable panels. Not a bad idea, but it would be a compromise as I plan on having hardwood flooring. The crawlspace should have plenty of room. It will be quite high in the pump area. But yes, I could house it elsewhere as well. My main concern is having a floor over the well shaft.
Old 03-08-2011, 09:27 AM   #8
Yes, building regs are an unknown for me, and I'll have to ask about it first.
As for future problems, If a driller has to come out anyway, then I would just drill a new well.
water spigots in crawl space linuxrunner Plumbing 6 12-30-2010 12:21 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
Water in Crawl Space turnergil Building & Construction 2 04-02-2010 09:26 AM
Inadequate center support in tight crawl space 4just1don Building & Construction 5 09-28-2008 04:29 PM
crawl space confusion shoestring General DIY Discussions 1 07-27-2008 02:06 PM
