Old 07-06-2012, 02:31 PM   #1
Question
Water well clogged / plugged how to cleanout
Hope this is in the right thread.
Been working around the ranch and found an old well. Talked to the family and they stated that it once had great water back in the 60's but hasn't been used since the oil company left.
Anyways, I measured down to 60 feet with a rope and chain to hear solid ground and no splashing. Another well on the propertly have water at 120 feet but are deeper than my rope will go.
Is there a way to blow out or clear this clog / plug?
I don't even know if it goes any further and no one else in the family knows either.
I have seen ways to make your own well. Would I use the same water/air method to clear this out or would it be better to contact a well service company in the area?
7SistersRanchTX is offline   Reply With Quote
Old 07-06-2012, 07:54 PM   #2
maybe they started to drilled and stopped..seen this before...could be to close to septic??? may needed moved.???/
Old 07-06-2012, 08:49 PM   #3
retired elect/hvac/plumb
plummen's Avatar
maybe there was water at that level in the past and it just dried out.
probably easier just to have a well driller come out and drill new hole and replace pump and tank
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 07-08-2012, 02:00 PM   #4
In the 70's there was water there. No where near septic as not really close to any old locations for houses. I know that it fed a watering tank for livestock back then.
Maybe it did dry out, water tables can change over 40 years.
The Following User Says Thank You to 7SistersRanchTX For This Useful Post:
ben's plumbing (07-08-2012)
Tags
cleanout, clogged, plugged, waterwell
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 01:05 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
