Old 07-16-2012, 04:53 AM   #1
water valves wont turn
Hello, im new here, my question is I want to shut off the water to my kitchen sink to change the fuacet. The sink plumbing has football-shaped shut-off valves for the hot and cold water. The problem is that these valves will not turn and seem to be frozen. what do i have to do to get them to turn so i can turn the water off?
pwf269 is offline   Reply With Quote
Old 07-16-2012, 06:39 AM   #2
Super Moderator
They are done----either install new shut offs (use 1/.4 turn ball valves) or simply shut off the water to the house instead of messing with the bad valves--
pwf269 (07-16-2012)
Old 07-16-2012, 06:54 AM   #3
Sometimes a drop of oil/PBblaster/wd40 will loosen things up. But often the seal around the valvle stem is damaged and will leak constantly. As suggested, might be time for new ones.
Most valves made in the last 20 yrs are cheapy types and can't be rebuilt. Generally it is not worth the effort, anyhow.
The Following 2 Users Say Thank You to Just Bill For This Useful Post:
oh'mike (07-16-2012), pwf269 (07-16-2012)
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 09:35 AM
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 10:47 AM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 12:31 PM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 03:17 AM
