Water From Tub Draining Into Basement - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-19-2011, 09:48 PM   #1
Water From Tub Draining into Basement
We have an unfinished basement. On the ceiling (which is the bottom of the floor from my upstairs), there is a metal plate covering where the drain to the tub is. Water is flowing into that and dipping into the basement.
I checked it today by running water for a short time and it didnt leak. When my daughters took their showers this evening, it leaked. And it is not a slow leak.
Any ideas?
Tom18 is offline   Reply With Quote
Old 10-19-2011, 09:58 PM   #2
DIY staff
Rewards Points: 7,174
The shower head pipe is a common cause of leaks like that----If you have a single handle mixer valve--remove the handle and the cover plate---run the shower---if it's leaking from the head you will see water dripping onto the mixer valve.
Old 10-19-2011, 10:20 PM   #3
Yes it is a single handle. Do I replace the handle in that situation? Or is the valve replaceable?
Old 10-19-2011, 10:29 PM   #4
DIY staff
The problem is up above----where the shower head pipe screws in behind the tile---
You are just opening up the cover so you can see if the leak is from the shower head--
That's the cause of leaks like you are describing more than half the time---
Old 10-19-2011, 10:40 PM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I'm betting (again) on a crappy tub spout. 9.5 times out of 10 it's a crappy tub spout.
Journeyman Plumber
Old 10-19-2011, 10:51 PM   #6
DIY staff
OP said that it didn't leak when he ran the tub --only leaked when daughter took a shower.
Old 10-19-2011, 11:35 PM   #7
Doing it myself
Alan's Avatar
From what I see on what seems like a bi-weekly basis now, it's the backpressure against a faulty or busted o-ring in the spout that causes the issue when showering.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
oh'mike (10-20-2011)
Old 10-20-2011, 08:49 AM   #8
Sounds like a minimal amount of water so I would assume it's not on the pressure side. Could be shower water running through a bad caulk joint or failed grout or it could also be the rubber seal behind the bathtub overflow. Hang a sheet of plastic on the wall where the control handles are and run the shower for awhile and see if your problem goes away. That will rule out any issues for those three possibilities.
fred54 is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
basement water issue zoolou Building & Construction 4 12-05-2010 06:05 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 12:59 PM
