-   -   Water From Tub Draining into Basement (http://www.diychatroom.com/f7/water-tub-draining-into-basement-120630/)
Tom18 10-19-2011 09:48 PM
We have an unfinished basement. On the ceiling (which is the bottom of the floor from my upstairs), there is a metal plate covering where the drain to the tub is. Water is flowing into that and dipping into the basement.
I checked it today by running water for a short time and it didnt leak. When my daughters took their showers this evening, it leaked. And it is not a slow leak.
Any ideas?
oh'mike 10-19-2011 09:58 PM
The shower head pipe is a common cause of leaks like that----If you have a single handle mixer valve--remove the handle and the cover plate---run the shower---if it's leaking from the head you will see water dripping onto the mixer valve.
Tom18 10-19-2011 10:20 PM
Yes it is a single handle. Do I replace the handle in that situation? Or is the valve replaceable?
oh'mike 10-19-2011 10:29 PM
The problem is up above----where the shower head pipe screws in behind the tile---
You are just opening up the cover so you can see if the leak is from the shower head--
That's the cause of leaks like you are describing more than half the time---
Alan 10-19-2011 10:40 PM
I'm betting (again) on a crappy tub spout. 9.5 times out of 10 it's a crappy tub spout.
oh'mike 10-19-2011 10:51 PM
OP said that it didn't leak when he ran the tub --only leaked when daughter took a shower.
Alan 10-19-2011 11:35 PM
From what I see on what seems like a bi-weekly basis now, it's the backpressure against a faulty or busted o-ring in the spout that causes the issue when showering.
:thumbsup:
fred54 10-20-2011 08:49 AM
Sounds like a minimal amount of water so I would assume it's not on the pressure side. Could be shower water running through a bad caulk joint or failed grout or it could also be the rubber seal behind the bathtub overflow. Hang a sheet of plastic on the wall where the control handles are and run the shower for awhile and see if your problem goes away. That will rule out any issues for those three possibilities.
