Water Trap In Vent Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-10-2015, 11:03 AM   #1
Rewards Points: 77
Water trap in vent line
So im adding a small vented sink in basement. In order to avoid cutting big hole in joist i wrapped it under. This vent goes all the way out and through roof. Should i be worried about rain water getting trapped into this thing?
nateo is offline   Reply With Quote
Old 01-10-2015, 11:20 AM   #2
Rewards Points: 77
Picture meeds rotated
Old 01-10-2015, 11:22 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 348
A vent may not drop in elevation or have pockets in them.
You can drill those joists with little worry. Just do not cut into the top or bottom cords.
Look along the joist to find the manufacturer's name. Then go to their website to find their drilling chart. You'll be surprised how big of a hole they'll let you drill....
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (01-10-2015)
Old 01-10-2015, 03:17 PM   #4
Green Hat
Rewards Points: 170
Agreed.
Your local building and codes office may also have information on how to build an approved supporting structure (I.E. Plumbers box) if need be. My office here in TN was very clear about what needed to be done.
Good luck!
Mills314 is offline   Reply With Quote
Old 01-10-2015, 04:02 PM   #5
Rewards Points: 1,678
Pipe it in such a way to allow it to drain at all times. Condensation will block it as it is.
Old 01-11-2015, 06:47 AM   #6
Rewards Points: 2
Basically while intent was there, the vent is not! Once a vent is manipulated in a manner which does not allow constant rise by 1/16"pfm it is "cut off" therefore non existent. You may be better off and much easier to just put a air admittance valve under the new sink.
Buz42812 is offline   Reply With Quote
Old 01-11-2015, 02:38 PM   #7
Just run the vent to the other vent coming up the wall in the verticle. Tie in at that point so it is self draining.
vacuum breaker question detroittigerfan Plumbing 17 10-12-2013 02:37 PM
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 05:10 PM
Hot Water Heater Problems Btabach Plumbing 7 05-21-2012 02:24 PM
Old water supply line a_lost_shadow Plumbing 7 04-20-2012 12:12 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
