Water Too High Or Toilet Seat Too Low? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-11-2014, 04:17 PM   #1
000
Exclamation
water too high or toilet seat too low?
Hi.
I have a problem with my toilet which I'm going to do my best to describe without getting graphic.
I come in contact with the cold water every time I sit down. Sometimes I also come in contact with the front rim the toilet. Either way, this feels very filthy and disgusting and I'm sure it's not safe.
So my question is, how do I remedy this problem without using embarrassing equipment like a 2nd, higher toilet-seat with bars/rails and such stuff?
I've considered an automatic toilet cleaning system, like Kaboom or NeverScrub but this wouldn't prevent me from coming in contact with the front of the toilet, where the automatic toilet cleaning system wouldn't be able to reach.
I'm a big person (366 lbs) so this is also an issue.
Thanks for reading!
000 is offline   Reply With Quote
Old 05-11-2014, 05:33 PM   #2
Rewards Points: 12,856
No way should the water be sitting in the toilet that high unless the drain is plugged up.
Small round toilet? If so switch it out for an oblong.
Old 05-11-2014, 05:35 PM   #3
Rewards Points: 1,688
Replace the toilet. Go with something like a CADET commercial toilet. They're oblong so you fit better and they're also taller than the residential toilets (I think 17 inches vs 15... or something like that)
Bob Sanders is offline   Reply With Quote
The Following 2 Users Say Thank You to Bob Sanders For This Useful Post:
ben's plumbing (05-11-2014), SHR Plumber (05-11-2014)
Old 05-11-2014, 05:41 PM   #4
Look for the letters ADA on the box.
Old 05-11-2014, 05:47 PM   #5
Rewards Points: 776
I think that I would switch it to a commercial toilet like in the handicapped stalls, sometimes called "comfort height".
And you are justified in feeling "germed" by contacting anything but the seat while using this thing.
ED
de-nagorg is online now   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
High water table upmaroon Plumbing 13 07-30-2010 10:25 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
