Water Tight Connection? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2010, 12:40 PM   #1
Rewards Points: 12
water tight connection?
what is the best way to make a good watertight connection between a plastic bucket top and a piece of 1" PVC pipe?
Leprichon is offline   Reply With Quote
Old 01-03-2010, 01:18 PM   #2
Rewards Points: 5,336
Plastic buckets don't have tops. If they did, you couldn't put water in them.
It would help if you mentioned what you are trying to do. There are usually other alternatives to the goal that might be better suited.
Ron
Old 01-03-2010, 04:57 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,712
Ayuh,... A 1" Bulkhead fitting...
Bondo is online now   Reply With Quote
Old 01-04-2010, 07:52 AM   #4
Yeah that's it.
SULTINI is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Low Hot Water Pressure jifisher Plumbing 10 07-27-2009 06:48 AM
hot water check valve? Ultrarunner2017 Plumbing 7 01-30-2009 01:36 PM
Water heater connection navysuit Plumbing 5 06-17-2008 09:52 PM
Water Mystery - Sump Pump Set Right? robertr4836 General DIY Discussions 4 02-13-2008 02:32 PM
