Old 09-18-2011, 09:51 PM   #1
Question
water tanks
is a 40 gallon electric water tank enough to support a two bath house?
reddog122199 is offline   Reply With Quote
Old 09-18-2011, 10:04 PM   #2
Stuck in the 70's
Blondesense's Avatar
water tanks
It depends more on how many people use those two bathrooms.
The Following User Says Thank You to Blondesense For This Useful Post:
reddog122199 (09-18-2011)
Old 09-18-2011, 10:07 PM   #3
water tanks
In my house, a 50 gallon is more than enough in the summer, but runs out often in the winter. Me, wife, 3 year old, and 1 year old. we live in TN.
broox is offline   Reply With Quote
Old 09-18-2011, 10:08 PM   #4
water tanks
just me and my fience and elderly mom
Old 09-19-2011, 09:22 AM   #5
Plumb or Die!
water tanks
Should be good enough.
plumber666 is offline   Reply With Quote
Old 09-19-2011, 09:43 AM   #6
water tanks
It depends.
JohnDsouza is offline   Reply With Quote
Old 09-19-2011, 10:24 AM   #7
AlbacoreShuffle's Avatar
water tanks
If you have room , I'd install a 50 gallon.
The difference in cost for the tank isn't much and the labor is the same.
AlbacoreShuffle is offline   Reply With Quote
Old 09-19-2011, 10:29 AM   #8
Doing it myself
Alan's Avatar
water tanks
Actually the cost of a 50 gallon is usually a lot cheaper than a 40 gallon.
Labor is not the same if it's plumbed for a 40 gallon and you have to move piping for a taller heater.
That being said, i'd go with a 50 if you have the space. Do you have laundry hookups and dishwasher in the house? If so, i'd definitely go 50. Then if you want to shower while the washer is going, it's not a huge problem.
Journeyman Plumber
Old 09-19-2011, 10:39 AM   #9
water tanks
Heres a spec sheet that may be helpful.
http://www.rheem.com/docs/fetchDocum...6-3e45bb7bf704
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
Lost Hot water pressure brile Plumbing 11 11-28-2010 03:59 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
