Water Tank Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-11-2012, 12:43 AM   #1
water tank leak
There is quite a bit of water around the connection of my water tank, I do not know where it is coming from, can anyone help please?
spacmancan is offline   Reply With Quote
Old 02-11-2012, 06:14 AM   #2
What kind of tank, well pressure tank, hot water tank, etc. Pics would help us. Can be anything from leaking pipe connections to a leaking tank. Water heaters often leak at the T&P(temp & pressure) valve, and whne the tank rusts through, from the tank itself.
Old 02-11-2012, 06:15 AM   #3
Rewards Points: 13,458
Hold it closer to the screen so I can see it better. If you can not find the leak and your standing there, how can we?
Post a picture of what you have.
Old 02-11-2012, 07:30 AM   #4
MarginallyQualified
Rewards Points: 2,464
Few people with an actively leaking WH tank have time to post on forums.
Especially follow up questions.
Your time will (almost always) be better spent heading down to the store to buy a new WH.
The "3 Main Things": Same size you have now. A brand name you recognize. 12 year warranty.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
well pressure tank leak wengang1 Plumbing 16 10-07-2010 08:59 AM
Water softener leak - how do I set it to bypass? Cylanth Plumbing 4 07-21-2010 09:24 PM
