Water System In Home - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-06-2010, 09:26 AM   #1
water system in home
we have a well and there is an issue with iron and sulphur, I am more concerned about the iron for it has ruined my bathrooms. The softner stopped working several years ago when we bought the home. I know the softner does not remove iron. Can I get an iron filter for the home and it remove iron without having a water softner. For some reason my husband will not put a softner in. He does not want to carry salt up and down the stairs. I am just trying to save my bathroom tubs and sinks not to mention the washer dryer and dishwasher. Thank you
loco moco is offline   Reply With Quote
Old 05-06-2010, 10:15 AM   #2
You can get a special iron and hydrogen sulfide filter and install it on your main line.
This might be a good option here:
http://www.home-water-purifiers-and-...ron-filter.php
The Engineer is offline   Reply With Quote
Old 05-06-2010, 11:22 AM   #3
Water Treatment
Rewards Points: 898
When you moved in was the softener working?
How good was the softener working when it was working?
Was all of the iron getting removed?
How much of the smell was getting removed when the softener was working and on line?
Akpsdvan is offline   Reply With Quote
Old 05-06-2010, 11:55 AM   #4
To get informed advice you really need to obtain and post a water analysis to include the quantity and type of iron, manganese, pH, and hardness at a minimum. A properly sized and spec'd water softener can handle significant quantities of clear water iron--but there are limits and at a point treatment specifically for the iron becomes necessary.
I don't recomment filters like the one posted above for whole house treatment with any significant quantity of iron because they are used up fairly quickly and are also prone to loading up and reducing water flow.
Bob999 is offline   Reply With Quote
Old 05-06-2010, 01:01 PM   #5
Water quality'n pump guy
Grocery and hardware along with all big box stores sell Iron Out or Super Iron Out and that will remove the rust stains from your fixtures, appliances and clothes etc..
Softeners do remove iron but there is a rather high limit. Your odor will not be removed by a softener and if your present softener has not been by passed, it could be adding odor to the water since it isn't being regnerated.
Tell that guy that wants to sleep in your bed most nights that he is supposed to love'n obey you and that you need a water analysis and working equipment and that he is going to lug salt or whatever as needed or pay consequences he will not like. Head up, chest out, big smile and just TELL him to git'er done, no asking will or could or would he, tell him to do it and then stop smiling as you stare into his eyes until he looks away. That will work most times.
Gary Slusser
23 years in water treatment and well pumps, 13 years on the 'net helping others to help themselves.
Gary Slusser is offline   Reply With Quote
Old 05-06-2010, 05:46 PM   #6
Licensed Master Plumber
Well then, that was pretty demeaning and stereotypical
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 05-06-2010, 05:56 PM   #7
you'll make somebody a good wife Gary
The older I get the better I was
Water leak, over 1 gallon every 5 minutes. carl1864 Plumbing 13 01-15-2010 12:31 PM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 05:07 PM
Decreased Water Pressure in home Gordon07 Plumbing 4 12-03-2009 11:05 AM
need info on heating/hot water system please donaldcarter55 HVAC 1 07-07-2009 09:16 AM
boiler / Over-pressurizing cparke HVAC 1 05-21-2008 05:54 AM
