Old 12-06-2011, 10:07 AM   #1
Water Swishing Through Central Heatin Radiators
I am having problems with constant water noise in radiators, have put on thermostst valves flushed out system etc. if I try to balance system I get Scretching noise and have to turn the outlet valve to the off position to stop the noise at the point it stops I have switched outlet flow off altogether.
I have a Bosh Worcester Boiler and I can't find anything in the manuel regarding slowing down the pump. Has anyone any idea of what I should do next?
Petro c is offline   Reply With Quote
Old 12-06-2011, 11:32 AM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,... My guess is, once ya get the Air outa the system, everything will be just Fine....
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
