#1 |
water supply for washer/dryer
I am relocating my washer /dryer and dont know best way to run the plumbing. I have two choices. I can run the pipes into the attic and come down into new location or I can run the supply lines from the current location through a cinder block wall, 15 foot run and back in to the new location. I am not too keen on waterpipes overhead. I really prefer the outside run but here is my question? How to avoid a frozen burst pipe in winter. I suppose if the lines are deep enough no problem. What about where they come out and back in?? Just foam wrap? I thought I would run both lines inside a larger conduit and fill with expanding foam (Great Stuff). Is this overkill? How do I run through the block and give it a neat and secure look?
Thanks for the help JK |
#2 |
A "Handy Husband"
Assuming the washer/dryer are in a laundry / utility room, why not run the plumbing along the inside wall from the old to the new location?
#3 | |
water supply for washer/dryerQuote:
J |
| Display Modes | |
| How to properly drain and flush a hot water heater? | speedster1 | Plumbing | 9 | 04-17-2012 10:55 PM |
| How Do I Properly Shock Chlorinate a Water Softner | classicflytyer | Plumbing | 5 | 07-14-2009 01:15 AM |
| water supply layout | wglord | Plumbing | 1 | 07-13-2009 01:07 PM |
| low hot water pressure | angus242 | Plumbing | 10 | 01-08-2009 12:41 PM |
