Water Supply Valve Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-21-2012, 06:11 PM   #1
Water supply valve replacement
I need to replace a supply valve in a closet of water heaters within a building of several units. If I turn off the water main and remove my bad supply valve.....will the water from all the other water heaters and floors above drain out from the gravity?? I just want to know if turning off the water main will be unough for me to cut pipe & replace my water heater supply valve...Thanx
waltyg is offline   Reply With Quote
Old 03-21-2012, 06:17 PM   #2
DIY staff
Rewards Points: 7,174
The whole building is going to drain--slowly.
Consider using a JETSWEAT tool----it is a tool that slips onto the pipe and has an expanding plug---
Slip the valve on over the slender handle--sweat---remove ---close valve
waltyg (03-21-2012)
Old 03-21-2012, 06:22 PM   #3
DIY staff
http://www.brenelle.com/
Spelled that wrong--Jet Swet
waltyg (03-21-2012)
Old 03-21-2012, 07:05 PM   #4
Thank you Mike for your response, I am very excited to learn about the Jet Swet tools and will certainly add them to my tools, however I need the replace my supply valve because it is broken in the closed position, It does not look like this can be used on a valve in the closed position. What do you think??
Old 03-21-2012, 07:07 PM   #5
Oh'Mike
Old 03-21-2012, 07:36 PM   #6
MarginallyQualified
Rewards Points: 2,464
While the water is off anyway...
spend another $100 or so on a few additional service valves so you can isolate easier.
Old 03-21-2012, 10:02 PM   #7
Is the pipe iron or copper?If its copper you could rent a propress crimp a valve on in seconds
plumberman134 is offline   Reply With Quote
Old 03-21-2012, 11:06 PM   #8
Ravenworks's Avatar
Originally Posted by oh'mike View Post
JETSWEAT tool---
What a slick tool,so simple who would have thought?
Ravenworks is offline   Reply With Quote
Old 03-22-2012, 05:55 AM   #9
DIY staff
OP---Have the city shut off the water----cut the pipe on the meter side----then cut the building side and quickly shove the tool into the pipe and twist the handle----
clean the pipe --and new ball valve---flux both surfaces---and slide the open valve over the tool and onto the pipe.
Solder----remove the tool and close the valve.
This tool is a life saver--I used it on a live 3/4" main line when the Buffalo box couldn't be located under 2 feet of snow.
( Just a thought---most areas require a licensed plumber for multi family dwellings)
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
main water supply valve leaking hohadcr Plumbing 10 07-31-2009 07:27 PM
Price Pfister 3 Valve Shower Replacement water issue LeviDIY Plumbing 3 06-18-2009 02:59 PM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 10:26 PM
