Water Supply Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-02-2011, 10:40 PM   #1
water supply valve
I need to change my main house shutoff from a gate valve to a ball valve. I have 3/4" soft copper coming in and 1" galvanized pipe inside. What is the best way to make this connection?
jasontf is offline   Reply With Quote
Old 06-03-2011, 06:48 AM   #2
DIY staff
Rewards Points: 7,174
Post a picture so we have an idea of the space involved---
Generally --cut copper,slowly ,so you are shaping the soft tube with your tubing cutter--
Sweat on a new valve--sweat on copper with a dielectric union on the output side---join onto the house plumbing.
Old 06-03-2011, 06:52 AM   #3
Rewards Points: 1,214
Why not replace the gate valve with a gate valve or replace it with a ball valve ? You need full flow through your main valve.
COLDIRON is offline   Reply With Quote
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 03:26 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 08:18 PM
