Water Supply For A Temp. Toilet? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-23-2011, 02:11 AM   #1
Water supply for a temp. toilet?
Our one and only toilet (upstairs) has to be pulled tomorrow due to a floor install. And since we don't have an outhouse, I must come up with a temporary, non-permanent solution.
I have a 4 1/2" O.D., ABS pipe protruding up from the slab in the basement (bath rough in) which I have installed a toilet on. The issue is that I need a water supply. And fast! This too has to be temporary since the walls have yet to be built for the basement bathroom.
I have access to both a 3/4" and 1/2" cold water line (copper). Other than cutting and soldering new copper, which is not an option at this point, is there anything available from the local home stores I could use for the temporary supply line?
Mn_Shooter is offline   Reply With Quote
Old 01-23-2011, 07:51 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 606
Ayuh,... A 5 gallon bucket of water, filled from whereever ya want....
Old 01-23-2011, 08:26 AM   #3
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Good idea, Bondo .....just make sure you plug the supply hole in the tank..............
........a garden hose hooked up with a few adapters???
That would be a perfect question for the Homeboy Depot guys.......
tcleve4911 is offline   Reply With Quote
Old 01-23-2011, 08:56 AM   #4
DIY staff
Rewards Points: 7,174
Do you have an ice maker waterline? If so there is a supply---1/4" but a clever person could figure out an adapter to 3/8.
Old 01-23-2011, 10:34 AM   #5
Household Handyman
Rewards Points: 1,408
Bondo's correct on this: If you have the toilet installed on the pipe in the basement, then all you have to do is pour the water into the toilet bowl, not the tank to flush material down the drain. Interesting concept you have there.
Old 01-23-2011, 11:01 AM   #6
Good call, Bondo. But highly unlikely that would fly with the ladies of the house. This solution needs to be a self contained, on site supply. As in sit down, do whatcha gotta do, flush and go on your way. If it includes carrying 5 gallon pails from the upstairs to flush with.... I'll just say no.
Looks like it's cut and solder time.
Old 01-23-2011, 11:11 AM   #7
use a sharkbite T to cut and fit, run 1/2"pex to 1/2" compression cut off and toilet riser at toilet. done
The older I get the better I was
Old 01-23-2011, 11:23 AM   #8
To confirm...
The sharkbite fitting is to be cut and fit into the 1/2" copper. Then use PEX to a 1/2" compression cut off, to the riser then to the tank?
Old 01-23-2011, 11:25 AM   #9
my understanding of the shark fitting is the plastic insert gets removed where copper pipe is but stays for plastic pipe.
Old 01-23-2011, 11:30 AM   #10
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Depending where the washing machine is. Put a hose tee on the cold water supply and run a garden hose to the toilet location. Use a hand held nozzle to fill the toilet tank or rig some adapters to connect the hose to the fill valve. First option is easiest, but make sure you plug the fill valve inlet if you do it that way.
To connect to the toilet, 3 fitting needed;
Hose to pipe adapter http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Stop valve http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Toilet supply tube http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 01-23-2011, 02:37 PM   #11
In a little over my head
Rewards Points: 706
My first thought was to use a garden hose. Then I saw you were in Minnesota. Might not work in January. The T off the washing machine to a garden hose sounds like how I'd do it. If you'll be using it long term, then cob up some adapters to make the hose fit up to the fill valve.
ratherbefishing is offline   Reply With Quote
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 03:26 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Extending Water Supply Box In Laundry Room hsl Building & Construction 0 11-18-2009 10:21 AM
replacing toilet...basic questions mcvane Plumbing 4 01-16-2009 11:11 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
