Water Supply Shut-off For Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-16-2008, 12:02 AM   #1
Water supply shut-off for toilet
Hello Everyone. I'm new to the site and need some advice. I am a 63 years young grandma and try to do all of my own repairs. I also help my children whenever I can. We all live in Manufactured Homes of various years and sizes. Right now, I'm trying to help my daughter replace a bad toilet and increase support in the floor around it. The trailer is quite old and the toilet's water supply line doesn't seem to have a shut-off valve. I could sure use some advice on what to do about it. Thanks in advance. Junebug
junebug82644 is offline   Reply With Quote
Old 05-16-2008, 01:06 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
You need to go to a place that sells mobile home plumbing supplies, and get a shut-off valve and a flex connector that goes from the valve to the toilet tank from it, using the same type of plumbing (1/2" plastic?).
Mike
Mike Swearingen is offline   Reply With Quote
Old 05-17-2008, 12:18 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Mike
Usually 3/8" polybutelyne in older mobiles
Journeyman Plumber
Old 05-18-2008, 02:25 PM   #4
Hi again. Will I have to tear up the floor to shut the water off, or should there be a main shut-off that's easy to find? Thank you for your help.
Ellen
Old 05-18-2008, 02:31 PM   #5
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
Junebug,
If you have a water meter you can certainly turn the water off there, if not you probably have a shut off valve under the house. Look for the water pipe coming out of the ground under the trailer and the valve should be right there.
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Old 05-19-2008, 09:23 AM   #6
Doing it myself
Alan's Avatar
Originally Posted by mstplumber View Post
Junebug,
Could be in a green valve box in your yard as well, depending on who plumbed the water service.
Journeyman Plumber
Toilet water Supply- Shut off valve kcreds Plumbing 5 04-07-2008 12:44 PM
can't shut off cold water from main disconnect DanBress Plumbing 3 01-06-2008 06:20 PM
I cannot shut water off. Floorwizard Plumbing 12 06-08-2007 04:05 PM
dripping from water shut off valve underneath the toilet maitri Plumbing 4 12-10-2006 03:58 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
