-   -   Water supply shut-off for toilet (http://www.diychatroom.com/f7/water-supply-shut-off-toilet-21060/)
junebug82644 05-16-2008 12:02 AM
Hello Everyone. I'm new to the site and need some advice. I am a 63 years young grandma and try to do all of my own repairs. I also help my children whenever I can. We all live in Manufactured Homes of various years and sizes. Right now, I'm trying to help my daughter replace a bad toilet and increase support in the floor around it. The trailer is quite old and the toilet's water supply line doesn't seem to have a shut-off valve. I could sure use some advice on what to do about it. Thanks in advance. Junebug
Mike Swearingen 05-16-2008 01:06 AM
You need to go to a place that sells mobile home plumbing supplies, and get a shut-off valve and a flex connector that goes from the valve to the toilet tank from it, using the same type of plumbing (1/2" plastic?).
Mike
Alan 05-17-2008 12:18 AM
Mike
Usually 3/8" polybutelyne in older mobiles
junebug82644 05-18-2008 02:25 PM
Hi again. Will I have to tear up the floor to shut the water off, or should there be a main shut-off that's easy to find? Thank you for your help.
Ellen
mstplumber 05-18-2008 02:31 PM
Junebug,
If you have a water meter you can certainly turn the water off there, if not you probably have a shut off valve under the house. Look for the water pipe coming out of the ground under the trailer and the valve should be right there.
Alan 05-19-2008 09:23 AM
Originally Posted by mstplumber (Post 124003)
Junebug,
Could be in a green valve box in your yard as well, depending on who plumbed the water service.:thumbup:
