Water Supply To New Bathroom - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-13-2011, 08:56 PM   #1
MikeKy55's Avatar
Rewards Points: 254
Water supply to new bathroom
Still working on the basement. I'm thinking now about adding water to the new bathroom given that I now have a way to drain it out. I will be tying into 3/4 inch lines about 10 feet from the new bath. My thoughts are to keep 3/4 around the bathroom and reduce to 1/2 inch as I take off to each valve. Is this the best plan? I wondered if I used 1/2 inch all the way I would have less volume to the lav, WC and tub/shower. I'm not clear on what effect pipe sizing has on pressure at the delivery points. Thanks
MikeKy55 is offline   Reply With Quote
Old 01-13-2011, 09:11 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 546
If your water pressure is good, you can prolly pipe the last 2 fixtures on 1/2". If using copper, be sure to reem your pipe and regardless of the type of pipe, be conservative with the fittings and anchor the pipes well
Old 01-13-2011, 09:33 PM   #3
MikeKy55's Avatar
Rewards Points: 254
Copy that, thanks!
Supply valve to bath faucet doesn't stop water Kurt123 Plumbing 2 09-05-2010 09:48 PM
water supply layout wglord Plumbing 1 07-13-2009 12:07 PM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 09:26 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
No water coming from main water line in bathroom sassylaroo Plumbing 6 10-29-2007 05:34 AM
