Water Supply Lines - Does This Look OK - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-25-2010, 12:27 PM   #1
Water supply lines - Does this look OK
First time running new supply lines to this extent. The picture attached shows what I plan to supply a washing machine (leftmost hot/cold lines) a laundry tub (middle hot/cold lines) and a bathroom vanity (rightmost hot/cold lines). Does this routing look sensible???
Cheers
Chris.
chrisinmontreal is offline   Reply With Quote
correct size pipe for water lines jce Plumbing 2 04-11-2010 08:23 PM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 05:07 PM
Extending Water Supply Box In Laundry Room hsl Building & Construction 0 11-18-2009 09:21 AM
hot water check valve? Ultrarunner2017 Plumbing 7 01-30-2009 01:36 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
