Water Supply Lines - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-28-2012, 06:20 AM   #1
water supply lines
can someone explain to me where the water supply line enters your house coming from the meter, what size pipe is normally used and the route this pipes takes once it has entered your crawl space.
detail would be appreciated.
Thanks in advance
Joe Tilghman is offline   Reply With Quote
Old 02-28-2012, 06:43 AM   #2
Supply normally enters from the street side, about 3-4ft down the foundation from grade level, depending on your frost line. If it comes up in a crawl space, it should be toward the center of the house to reduce freezing problems, and be insulated. It is usually a 3/4 or 1" line, which can be copper or plastic, or if old, galvanized pipe. There should be a main shutoff where it enters the house.
Our meters are located inside the house, so the line goes directly to the meter first.
Old 02-28-2012, 06:53 AM   #3
After the shutoff does the line enter the house and go directly to the water heater as a 3/4" line and then T off to 1/2" to supply faucets etc??
Old 02-28-2012, 07:20 AM   #4
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Joe Tilghman View Post
After the shutoff does the line enter the house...
The shutoff should be INSIDE the house very close to where the pipe enters.
...and go directly to the water heater as a 3/4" line and then T off to 1/2" to supply faucets etc??
After the shutoff... it'll go everywhere that the original plumbing plan called for (cold) water; using whatever size pipe the original plumber chose to use.
One of those places will be the water heater.
Old 02-28-2012, 07:25 AM   #5
Thanks for the replys guys.
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
slow hot water lines sobro Plumbing 3 11-05-2010 10:44 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 05:07 PM
Extending Water Supply Box In Laundry Room hsl Building & Construction 0 11-18-2009 09:21 AM
