Water Supply Line Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-07-2009, 10:30 PM   #1
Question
Water supply line replacement
I need to have my badly leaking, old, galvanized supply line replaced; it runs from the meter near the street through the front yard, under an upstairs garage slab and into a basement storage room where it supplies the house.
I have had two quotes, both using "A" pex line. The difference in the two quotes is that one wants to run the new line to the house, go into the upstairs garage, up the wall and across the ceiling, down the wall and into the storage room near the floor of the garage.
The other wants to run the pex to the house and continue under the slab, just as the old line is run. This would involve boring through either the compacted fill under the slab, or the slab itself. This second method would be less noticeable, but I worry about the wisdom of boring through the slab or it's compacted fill material and how the pex line will hold up in that medium. I wonder if the compaction around the new line will sink and I'll have problems later with the garage slab. Both quotes are almost identical in price. Any ideas or comments on which is best or wisest to do?
bamaknox is offline   Reply With Quote
Old 01-08-2009, 01:10 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I would go for the first one as it is more accessible for future repairs, and not the slab. PEX is definitely the way to go.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 01-08-2009, 08:51 AM   #3
RippySkippy's Avatar
Where are you located? In a warm environment, I'd consider the first... in the cold, second. It sounds like the fist will have a bunch of fittings...not that they will leak...it's just a point to consider. I like to avoid as many fittings/ turns as possible.
If the quotes were the same...I'd go under the slab, depending on your soil they will be deep enough to not affect the integrity of the slab, and PEX is durable and will be fine underground.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Tags
"boring under slab" , "water supply"
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 10:24 AM
No water flow from house supply to fridge garyb123 Plumbing 23 12-24-2007 12:27 PM
No water coming from main water line in bathroom sassylaroo Plumbing 6 10-29-2007 05:34 AM
hot pilot light supply line dlkk HVAC 1 02-24-2006 05:45 PM
