Old 09-06-2011, 04:17 PM   #1
water supply line to a new dishwasher install
ok...i'm installing a new dishwasher where there has never been one before. i'm new to this and don't know all the proper lingo so i'm gonna do my best. i was wondering if they make a connection that will allow me to tap into my hot water supply line to my sink, and then off of that run two seperate supply lines, one to my sink and the other to my dishwasher. please help!!!!
phillips48bpd is offline   Reply With Quote
Old 09-07-2011, 05:42 AM   #2
There is a piercing valve that some use on copper lines. It would go over your existing copper line and it pierces the pipe and allows the flow of water to go to your dishwasher. I hope I got it straight that you only want to add a dishwasher where there was not one before. You will still need to deal with the drain, and ensure you have a vent stack near enough to have air behind your water for your drain to flow.
fixrite is offline   Reply With Quote
Old 09-07-2011, 07:25 AM   #3
Super Moderator
There is a double outlet shut off valve available ---two 3/8" outlets ----
Old 09-07-2011, 07:48 AM   #4
Just call me Andrew
I would not use a piercing valve, they are prone to leaks. i'd go with what Mike suggested, something like this:
http://www.brasscraft.com/products.aspx?id=204
Andrew
secutanudu is offline   Reply With Quote
The Following 2 Users Say Thank You to secutanudu For This Useful Post:
oh'mike (09-07-2011), plumber666 (09-07-2011)
Old 09-07-2011, 08:04 AM   #5
Super Moderator
Those piercing valves should be banned---nothing but trouble.
Old 09-07-2011, 08:09 AM   #6
Piercing Valves
COLDIRON is offline   Reply With Quote
Dishwasher water supply line too small? porpoise1877 Plumbing 10 09-07-2011 09:34 AM
Water supply line runs through footing site WillK Building & Construction 19 03-15-2011 02:39 PM
Water supply line on the back has a leak lauraochoaanp Appliances 3 08-31-2010 07:19 AM
sealing around copper water supply line dazedanconfused Building & Construction 4 09-22-2009 05:55 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
