Old 07-13-2009, 11:26 AM   #1
water supply layout
I am an occaisional plumber and it has been a while... I am about to install a new water supply system in a mountain cabin. I have a 3/4 female threaded fitting coming off my well pressure tank. I want to run 3/4 supplies as much as possible to the 2 baths, kitchen, washer, and outside taps. Several questions: Should I run a single 3/4 pex over the water heater and T the water heater supply line down to the water heater or do it differently? Second, should I use the flex copper connectors to and from the water heater? Runs are fairly short and I like the idea of using a hot and cold manifold with home runs to the fixtures. of course no manifolds are for sale around here. Can I make my own maifolds with PEX fittings and cutoffs of willa 3/4 manifold not supply enought pressure?
many thanks, Bill
wglord is offline   Reply With Quote
Old 07-13-2009, 01:07 PM   #2
RippySkippy's Avatar
water supply layout
That would work.
They work. If you're using PEX there's no need to use Flex, use standard 3/4" rigid copper with a union and shutoff on the in and out side (so when you have to replace the hot water heater you will have an easy disconnect.) Check with your instructions and/or the PEX instructions to determine the distance from the water heater to PEX distance you must maintain...most I believe are 18".
Sure you can...but there are also many online sources that you may want to check into (price check the items you may be interested in...this site runs high). By the time you purchase the valves and T's you will have more into it than if you can find an online source. Plus a manifold will look much cleaner and reduces the number of connections by about 2/3.
If you go with mainifolds, unless you have a high volume fill like a whirlpool tub, 1/2" will supply all you will need. If you go with out the manifold, sure, run 3/4" to the group, and split off with 1/2". Especially with the hot side....if you have a 3/4" pipe serving 3 fixtures in a manifold I will almost gaurantee you will be posting back wanting to know how to speed up the hot water delivery. If you have a run of decent length, there's many gallons of cold water to replace before the hot is available.
3/4" pipe will NOT increase or decrease pressure...it will affect volume.
Hope this get's you started...
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
City water supply to meter in house Watership Down Plumbing 2 07-08-2009 11:39 AM
Very Low Hot Water Pressure. PAS1970 General Discussion 2 02-25-2009 04:01 PM
Cold water not working in washing machine. 68MHJCs Appliances 15 01-20-2009 06:18 AM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 11:24 AM
Can water supply pipes be PVC?? i need general help... hallbum Plumbing 5 12-10-2005 02:22 AM
