Water Supply For Ice Machine - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-15-2012, 02:51 PM   #1
Water supply for ice machine
I know this should be simple. The feed line is cooper and then there is this valve. I thought it would just twist close to stop the water flow, but it does not seem to do that. It just turns. I need to move the fridge, and have to disconnect the line from the plastic tube side. I don't plan on putting the fridge right back as I have to do work in the area it is in.
I am worried about not being able to control the water flow once I disconnect. Has anyone worked with this type of valve before?
Thanks in advance.
Water supply for ice machine-img00150-20120508-1719.jpg   Water supply for ice machine-img00149-20120508-1719.jpg
jabba is offline   Reply With Quote
Old 05-15-2012, 05:03 PM   #2
Rewards Points: 150
When those little valves get some age they fail often. You will have to trace your copper feed line back to where it taps to a larger copper line and see if there is another shut off valve that may stop the flow of water to the ice maker line....
If no valve is found that works, you will have to shut off the water to the whole house to change that little valve. ( Unless your super fast and dont mind getting the kitchen floor drowned while installing a new 1/4 inch valve while the water is still on to it. good luck
Jeeps is offline   Reply With Quote
Old 05-15-2012, 05:59 PM   #3
Rewards Points: 14,010
I've never seen that style before but since it just turns it may be a ball valve which may turn off by simply turning that handle so it does not line up with the tube.
Washing machine water supply Ultrarunner2017 Plumbing 4 03-07-2011 06:35 AM
low water pressure from well pump supply dolfan13jmb Plumbing 4 03-03-2011 01:28 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
New Faucets - Rural Water Well Supply terra3 Plumbing 2 02-25-2010 05:41 PM
Cold water not working in washing machine. 68MHJCs Appliances 15 01-20-2009 05:18 AM
