#1 |
Water Supply Connection for House and Irrigation
I'm installing an irrigation system and I need to replace the tee that goes into my house to use one side for my sprinklers (instead of an existing hose bib). The existing installation is 3/4" copper pipe (from the meter) to a compression fitting, then the main shutoff 1", then a galvanized union 1", then the tee into the house and hose bib. When I replace the tee, must I use galvanized again? I would prefer pvc with threaded connections, but this is above ground and I don't think pvc can be used above ground, correct? The issue is that the hose bib is the wrong direction and a 1/2" connection where I need a 1" connection for irrigation.
| Tags |
pvc, supply, water ![]() |
| Display Modes | |
| idea for indoor basement water irrigation | Red Squirrel | Building & Construction | 21 | 05-01-2011 03:57 PM |
| Replacing main water supply valve on pvc pipe | FL Surfer | Plumbing | 1 | 09-19-2010 07:02 PM |
| Water leak, over 1 gallon every 5 minutes. | carl1864 | Plumbing | 13 | 01-15-2010 01:31 PM |
| Whoa, how much water can my irrigation system use??? | J187 | Landscaping & Lawn Care | 19 | 11-10-2008 04:04 PM |
| Sanity check - water collection for irrigation - from creek bed | So cal Man | Landscaping & Lawn Care | 2 | 08-14-2008 07:16 PM |
