-   -   Water Supply Connection for House and Irrigation (http://www.diychatroom.com/f7/water-supply-connection-house-irrigation-106304/)
jasontf 06-01-2011 10:00 PM
I'm installing an irrigation system and I need to replace the tee that goes into my house to use one side for my sprinklers (instead of an existing hose bib). The existing installation is 3/4" copper pipe (from the meter) to a compression fitting, then the main shutoff 1", then a galvanized union 1", then the tee into the house and hose bib. When I replace the tee, must I use galvanized again? I would prefer pvc with threaded connections, but this is above ground and I don't think pvc can be used above ground, correct? The issue is that the hose bib is the wrong direction and a 1/2" connection where I need a 1" connection for irrigation.
jasontf 06-01-2011 11:01 PM
Or using CPVC for the tee? Is there any alternative to putting in another galvanized tee?
