Water Stove - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-02-2011, 10:50 AM   #1
Water Stove
If you have a heat exchanger with top and bottom plumbing, why can't you have the supply line coming in the top and the return from the bottom. Thank you!
rbdarnell is offline   Reply With Quote
Old 10-02-2011, 11:42 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Are you talking about the tank water, or the coil water?
Journeyman Plumber
Old 10-02-2011, 11:46 AM   #3
Rewards Points: 150
No the old water stove.. i love steamed fish!
OhioHomeDoctor is offline   Reply With Quote
Old 10-02-2011, 11:49 AM   #4
Doing it myself
Alan's Avatar
Journeyman Plumber
Old 10-02-2011, 01:10 PM   #5
Plumb or Die!
It'll work, but not as well. Generally when using a heat exchanger for heating, you want your hottest source water heating up the coolest water from the other connections.
plumber666 is offline   Reply With Quote
Old 10-02-2011, 01:16 PM   #6
Coil water
Old 10-03-2011, 10:05 AM   #7
Rewards Points: 1,418
If there is a circulator pump in a continuous flowing water circuit going through the coil or baffle box (water back) and to a hot water tank then it does not matter which end the cold water pipe is connected to.
For gravity flow (no circulator) the hot flow to the tank must be from the top of the coil without the cold inlet entering at that point.
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 03:26 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
Well Water snuggles2010 Plumbing 3 04-13-2010 02:36 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
