Water Storage Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-06-2011, 05:42 AM   #1
Water storage tank
The water supply for the house I am renovating comes from a spring on a hill behind the house. The water pressure is gravity fed. I am currently redoing the plumbing in the house and I picked up a booster pump to help with the low pressure(16 psi at the main). Now I am wondering if I should add a storage tank before the pump so it doesn't run dry, and what type of tank I should get.
Thanks,
gseith is offline   Reply With Quote
Old 06-06-2011, 07:24 AM   #2
A storage tank would help even out pressure highs/lows, and provide some backup supply. The tank should be compatible for potable water. Check local codes. Definitely needs a pump to increase pressure.
I don't understand how you get along with 16# pressure.......how long does it take to get a glass of water???
Old 06-06-2011, 07:49 AM   #3
I timed it once; it took 1 minute to fill up a 5gal bucket. I already have a pump. I assumed I would need it since I added an upstairs bath that wasn't there before. I am just unsure on what type of storage tank I would need. Since I am running a booster pump after the tank do I need a pressure switch on the tank like a well?
Thanks,
Old 06-06-2011, 01:17 PM   #4
Rewards Points: 1,418
WHen you install a pump in a previously gravity fed water system you need a tank after the pump to provide an air cushion. Water goes in and out of the tank to maintain the system pressure within a fairly narrow range, say between 30 and 35 PSI.
It is important that the tank not fill up completely with water, losing the air cushion. If the tank does not have a bladder, the water will gradually absorb the air cushion and every month or so it is necessary to add air, usually through a spring loaded valve similar to a tire fill stem/valve on top.
A pressure switch is needed after the pump. Putting the switch in the tank usually gives the smoothest pump operation. No pressure switch is needed in a storage tank before the pump.
Old 06-06-2011, 04:12 PM   #5
I bought this pump
http://www.daveyusa.com/daveyusa/pro...ails.htn?id=16
The pump is supposed to regulate the pressure. After I purchased the pump I started worrying about there not being enough water to constantly supply the pump, so I thought I could add a tank before the pump. Is this going to be possible?
Thanks,
Old 06-07-2011, 04:40 PM   #6
Bump.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
Residential well water storage tank DIYchix Plumbing 4 09-15-2010 06:27 AM
hot water tank help needed psp Plumbing 2 08-22-2010 03:46 PM
Is a Hot Water Expansion Tank required Needagameplan Plumbing 9 04-27-2010 04:09 PM
