Water Storage - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-20-2012, 04:38 PM   #1
jburd964's Avatar
Rewards Points: 166
Water Storage
Thinking of adding a water storage tank in my attic while being on a city water system for emergency use. Anyone have any suggestions on how it could be set up?
Gun control isn't about guns, IT'S ABOUT CONTROL.
jburd964 is offline   Reply With Quote
Old 01-20-2012, 04:45 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
How many gallons at 8lbs to the gallon?
titanoman is offline   Reply With Quote
Old 01-20-2012, 05:33 PM   #3
MarginallyQualified
Rewards Points: 2,464
on a floor designed to support fiberglass batts and xmas ornaments?
Old 01-20-2012, 06:03 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,382
Ayuh,... 'n how big is yer attic access,..??
Old 01-20-2012, 06:45 PM   #5
jburd964's Avatar
Rewards Points: 166
I'm going to mount over closet after installing additional cross section of deck support. Volume to be determined by biggest tank fitting into 24"x 48" drop stair opening and weight that could be supported.
I'm not a professional., But I did stay at Holiday Inn Express last night.
Old 01-20-2012, 06:51 PM   #6
Disabled wood vet
titanoman's Avatar
So no more than 2' around over a closet. You'll be alright as long as the closet don't fall over.
Make sure the container is sealed or it will be putting a lot of moisture into the attic.
Old 01-20-2012, 06:54 PM   #7
MarginallyQualified
I bet you can stuff a pretty big one of these through that opening:
Bladder Water Tanks are designed to provide you with a flexible tank that can safely store your drinking water. Made from NSF 61 and FDA compliant materials, these tanks have stored drinking water for FEMA operations, rural construction sites, residential water storage and more. Sizes range from 2.5 to 210,000 gallons source
The Following User Says Thank You to TarheelTerp For This Useful Post:
jburd964 (01-21-2012)
Old 01-20-2012, 09:48 PM   #8
jburd964's Avatar
Rewards Points: 166
Thinking of using regular water well tank. Running all house water supply through tank, with check valve to prevent back flow.
Old 01-20-2012, 10:41 PM   #9
Rewards Points: 602
Here's another way to store some water if you know of an emergency in advance.
http://www.waterbob.com/Welcome.do;j...D5D0354DE4641C
gma2rjc is offline   Reply With Quote
The Following User Says Thank You to gma2rjc For This Useful Post:
Old 01-21-2012, 08:17 AM   #10
Rewards Points: 1,514
You do not want a tank with the water surface open to the atmosphere that draws in (non-sterile) air when you use water (and the air escapes when the tank refills).
So nowadays bladder tanks are the best choice. The tank should be positioned with the air valve upwards and the air valve should be left open. Optionally pressurize the tank while it is empty to about 3 PSI and close the air valve.
The higher you prepressurize the tank to, the less water will enter the tank before system pressure (water main pressure or well pump pressure) is reached and the inflow stops. Meanwhile if you let the tank fill up and then close the air valve, a partial vacuum will develop in the tank in time of need and gravity will not be enough to get water out.
The Following User Says Thank You to AllanJ For This Useful Post:
Tags
city water , emergency , preparedness , tank , water
Leaking water into under-garage storage room phauck Building & Construction 5 01-01-2011 06:39 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
